[GRASS-dev] Standalone GUI modules: Makefile
Martin Landa landa.martin at gmail.com
Tue Dec 4 13:27:14 PST 2012
2012/12/3 Glynn Clements <glynn at gclements.plus.com>:
>> `g.gui.%.tmp.html` from GuiScript is ignored and `%.tmp.html` from
>> Html.make is used instead.
> Right. It's supposed to choose the most-specific match (the one with
> the shortest stem), but that was broken in 3.81; it just uses the
> first match.
> Placing the pattern rule for g.gui.%.tmp.html before Html.make is
> included should avoid the issue.
thanks for the clarification. Unfortunately placing Html.make after
`g.gui.%.tmp.html` doesn't seems to help.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
