[GRASS-dev] [GRASS GIS] #1832: Python scripts are with mixed	tabs and spaces
    trac at osgeo.org
    Tue Dec 11 23:25:36 PST 2012
 Reporter:  klo          |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Python       |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by zarch):
 Replying to [comment:4 wenzeslaus]:
 > Moreover, the problem of white spaces in GRASS Python code is larger.
 > Try to use pep8 tool, the result is really bad. I think that if there
 > is some standard, we should keep it, at least the basic rules.
 +1
 > I understand the problem of editor settings. I encountered it, too.
 However,
 > I also know the opposite problem. My Python editor is confused and
 complains
 > about GRASS code and thus it is sometimes hard to use editor's code
 checking
 > features.
 +1
 why not use a pre-commit check, using pep8 like:
 https://gist.github.com/2903822  # pep8 + pyflakes
 http://widerin.org/blog/pep8-subversion-pre-commit-hook  # only pep8
 to force developers to use a standard?
 Using a standard can help to have a consistent python code and make the
 code easier to read.
 Pietro
 ps: pep8 command could be use also to convert all the existing python code
 to comply the pep8 directive...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:5>
