[GRASS-dev] [GRASS GIS] #1836: r.reclass.eq reports r.reclass rules file missing
GRASS GIS trac at osgeo.org
Thu Dec 13 08:21:52 PST 2012
 Reporter:  cwren    |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  Default  |     Version:  svn-trunk
 Keywords:           |    Platform:  MSWindows 7
      Cpu:  x86-64   |
 r.reclass.eq gives an error referring to a missing rules file and fails to
 produce an output. Using osgeo4w's grass70dev 7.0.svn-r54261-436
 r.rescale.eq --overwrite input=test at PERMANENT output=testout to=1,100
 Reading test at PERMANENT ...
 Description:
  Reclassify raster map based on category values.
  Creates a new raster map whose category values are based
 upon a reclassification of the categories in an existing
 raster map.
 Keywords:
  raster, reclassification
 Usage:
  r.reclass input=name output=name rules=name [title=string]
    [--overwrite] [--verbose] [--quiet]
 Flags:
  --o   Allow output files to overwrite existing files
  --v   Verbose module output
  --q   Quiet module output
 Parameters:
    input   Name of raster map to be reclassified
   output   Name for output raster map
    rules   File containing reclass rules
             "-" to read from stdin
    title   Title for the resulting raster map
 ERROR: Required parameter <rules> not set:
         (File containing reclass rules)
 Rescale test at PERMANENT[-5644,5207] to testout[1,100]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1836>
