[GRASS-dev] [GRASS GIS] #1765: variable length array error in r.terraflow with clang
GRASS GIS trac at osgeo.org
Tue Dec 18 11:47:15 PST 2012
  Reporter:  kyngchaos  |       Owner:  grass-dev@…
      Type:  defect     |      Status:  closed
  Priority:  normal     |   Milestone:  6.4.3
 Component:  Compiling  |     Version:  svn-develbranch6
Resolution:  fixed      |    Keywords:  clang
  Platform:  MacOSX     |         Cpu:  OSX/Intel
Comment(by neteler):
 Unfortunately the backport is incompliant with r.terraflow in G6:
 {{{[neteler at north r.terraflow]$ make
 c++ -c -I/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/include  -g
 -Wall   -DUSER=\"neteler\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT main.cc -o OBJ.x86_64-unknown-
 linux-gnu/FLOAT/main.o
 In file included from /home/neteler/grass64/dist.x86_64-unknown-linux-
 gnu/include/grass/iostream/empq.h:33:0,
 gnu/include/grass/iostream/empq_impl.h:41,
 gnu/include/grass/iostream/ami.h:39,
                  from common.h:27,
                  from main.cc:39:
 gnu/include/grass/iostream/embuffer.h: In member function ‘AMI_err
 em_buffer<T, Key>::substream_merge(AMI_STREAM<T>**, unsigned int,
 AMI_STREAM<T>*)’:
 gnu/include/grass/iostream/embuffer.h:989:3: error: ‘vector’ is not a
 member of ‘std’
 gnu/include/grass/iostream/embuffer.h:989:16: error: expected primary-
 expression before ‘*’ token
 gnu/include/grass/iostream/embuffer.h:989:17: error: expected primary-
 expression before ‘>’ token
 gnu/include/grass/iostream/embuffer.h:989:35: error: there are no
 arguments to ‘in_objects’ that depend on a template parameter, so a
 declaration of ‘in_objects’ must be available [-fpermissive]
 gnu/include/grass/iostream/embuffer.h:989:35: note: (if you use
 ‘-fpermissive’, G++ will accept your code, but allowing the use of an
 undeclared name is deprecated)
 gnu/include/grass/iostream/embuffer.h:1018:46: error: ‘in_objects’ was not
 declared in this scope
 gnu/include/grass/iostream/embuffer.h:1048:43: error: ‘in_objects’ was not
 gnu/include/grass/iostream/embuffer.h:1053:46: error: ‘in_objects’ was not
 gnu/include/grass/iostream/embuffer.h:1063:15: error: ‘in_objects’ was not
 gnu/include/grass/iostream/ami.h:39:0,
                  from common.h:27,
                  from main.cc:39:
 gnu/include/grass/iostream/empq_impl.h: In member function ‘AMI_err
 em_pqueue<T, Key>::merge_buffer(em_buffer<T, Key>*,
 AMI_STREAM<ExtendedEltMergeType<T, Key> >*, long int)’:
 gnu/include/grass/iostream/empq_impl.h:1250:3: error: ‘vector’ is not a
 member of ‘std’
 gnu/include/grass/iostream/empq_impl.h:1250:16: error: expected primary-
 gnu/include/grass/iostream/empq_impl.h:1250:17: error: expected primary-
 gnu/include/grass/iostream/empq_impl.h:1250:35: error: there are no
                  from common.h:27,
                  from main.cc:39:
 gnu/include/grass/iostream/empq_impl.h:1278:41: error: ‘in_objects’ was
 not declared in this scope
 gnu/include/grass/iostream/empq_impl.h:1313:37: error: ‘in_objects’ was
                  from common.h:27,
                  from main.cc:39:
 em_pqueue<T, Key>::merge_streams(AMI_STREAM<ExtendedEltMergeType<T, Key>
 >**, short unsigned int, AMI_STREAM<ExtendedEltMergeType<T, Key> >*, long
 int)’:
 gnu/include/grass/iostream/empq_impl.h:1375:3: error: ‘vector’ is not a
 member of ‘std’
 gnu/include/grass/iostream/empq_impl.h:1375:43: error: expected primary-
 gnu/include/grass/iostream/empq_impl.h:1375:61: error: there are no
 gnu/include/grass/iostream/empq_impl.h:1399:4: error: ‘in_objects’ was not
 gnu/include/grass/iostream/empq_impl.h:1427:36: error: ‘in_objects’ was
 gnu/include/grass/iostream/empq_adaptive_impl.h:30:0,
 gnu/include/grass/iostream/ami.h:41,
                  from common.h:27,
                  from main.cc:39:
 gnu/include/grass/iostream/empq_adaptive.h: In constructor
 ‘EMPQueueAdaptive<T, Key>::EMPQueueAdaptive(long int)’:
 gnu/include/grass/iostream/empq_adaptive.h:53:47: warning: delegating
 constructors only available with -std=c++11 or -std=gnu++11 [enabled by
 default]
 main.cc: In function ‘void printMaxSortSize(long int)’:
 main.cc:436:43: warning: format ‘%d’ expects argument of type ‘int’, but
 argument 4 has type ‘long unsigned int’ [-Wformat]
 main.cc:439:83: warning: format ‘%d’ expects argument of type ‘int’, but
 main.cc: In function ‘int main(int, char**)’:
 main.cc:622:16: warning: zero-length gnu_printf format string [-Wformat-
 zero-length]
 In file included from main.cc:43:0:
 grass2str.h: In instantiation of ‘AMI_STREAM<T>* cell2stream(char*,
 elevation_type, long int*) [with T = float; elevation_type = float]’:
 main.cc:558:25:   required from here
 grass2str.h:144:3: warning: format ‘%lld’ expects argument of type ‘long
 long int’, but argument 5 has type ‘off_t {aka long int}’ [-Wformat]
 gnu/include/grass/iostream/ami.h:27:0,
                  from common.h:27,
                  from main.cc:39:
 gnu/include/grass/iostream/ami_stream.h: In instantiation of ‘AMI_err
 AMI_STREAM<T>::write_item(const T&) [with T = float]’:
 grass2str.h:128:4:   required from ‘AMI_STREAM<T>* cell2stream(char*,
 gnu/include/grass/iostream/ami_stream.h:583:3: warning: comparison between
 signed and unsigned integer expressions [-Wsign-compare]
 AMI_STREAM<T>::read_item(T**) [with T = short int]’:
 grass2str.h:193:4:   required from ‘void stream2_CELL(AMI_STREAM<T>*,
 dimension_type, dimension_type, char*, bool) [with T = short int;
 dimension_type = short int]’
 main.cc:575:51:   required from here
 gnu/include/grass/iostream/ami_stream.h:521:3: warning: comparison between
 AMI_STREAM<T>::read_item(T**) [with T = float]’:
 dimension_type, dimension_type, char*, bool) [with T = float;
 main.cc:580:62:   required from here
 AMI_STREAM<T>::read_item(T**) [with T = labelElevType]’:
 grass2str.h:274:3:   required from ‘void stream2_CELL(AMI_STREAM<T>*,
 dimension_type, dimension_type, FUN, char*) [with T = labelElevType; FUN =
 labelElevTypePrintLabel; dimension_type = short int]’
 main.cc:585:26:   required from here
 AMI_STREAM<T>::read_item(T**) [with T = sweepOutput]’:
 grass2str.h:448:3:   required from ‘void stream2_FCELL(AMI_STREAM<T>*,
 dimension_type, dimension_type, FUN1, FUN2, char*, char*) [with T =
 sweepOutput; FUN1 = printAccumulation; FUN2 = printTci; dimension_type =
 short int]’
 main.cc:609:36:   required from here
 make: *** [OBJ.x86_64-unknown-linux-gnu/FLOAT/main.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1765#comment:9>
