[GRASS-dev] [GRASS GIS] #1801: r3.in.ascii fails in GRASS6.4.3
GRASS GIS trac at osgeo.org
Wed Dec 19 01:37:43 PST 2012
 Reporter:  helena                        |       Owner:  grass-dev@…
     Type:  defect                        |      Status:  new
 Priority:  critical                      |   Milestone:  6.4.3
Component:  Raster3D                      |     Version:  svn-releasebranch64
 Keywords:  r3.in.ascii, raster3d import  |    Platform:  MacOSX
      Cpu:  OSX/Intel                     |
Comment(by neteler):
 (This also applies to GRASS 7)
 The default:default looks confusing and useless to me:
              nv   String representing NULL value data cell (use 'none' if
 no such value)
                   default: none
            type   Data type used in the output file
                   options: default,double,float
                   default: default
       precision   Precision used in the output file (default, max, or 0 to
 52)
                   default: default
     compression   The compression method used in the output file
                   options: default,rle,none
                   default: default
   tiledimension   The dimensions of the tiles used in the output file
                   default: default
 Bad initialization in lib/g3d/g3dparam.c I suppose.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1801#comment:3>
