[GRASS-dev] GRASS Vector Support
Brian Sanjeewa Rupasinghe jinkabs at gmail.com
Fri Dec 28 21:28:19 PST 2012
I need to automate some GRASS functions in my research work. If there is a
possibility to build gdal_grass plugin for Windows it is highly
appreciated. Even the Python scripts that call GRASS functions from outside
for MS_Windows do not connect with GRASS even though the instructions
provided in the GRASS wiki is followed. I have posted this problem in
grass-windows forum and finally advised me to bring the problem down to
grass-dev list.
On Sat, Dec 29, 2012 at 2:28 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Markus,
> On Fri, 28. Dec 2012 at 21:33:47 +0100, Markus Neteler wrote:
> > please apologize for a direct question:
> > Would it be possible for you to compile
> > http://download.osgeo.org/osgeo4w/release/grass/gdal-grass/
> > against the current OSGeo4W?
> Um, claiming that's it's impossible, would be a lie.
> But I don't maintain GRASS in OSGeo4W anymore - and QGIS, which I
> originally
> built GRASS and the GDAL GRASS plugin for, doesn't need GRASS support in
> GDAL
> anymore.  Therefore the old package is unmaintained and is marked obsolete.
> Martin Landa took over GRASS maintenance in OSGeo4W - maybe he has more
> interest in building the plugin...
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121229/c68c7810/attachment.html>
