[GRASS-dev] GRASS Vector Support
Jürgen E. Fischer jef at norbit.de
Sat Dec 29 08:42:00 PST 2012
Hi Brian,
On Sat, 29. Dec 2012 at 10:58:19 +0530, Brian Sanjeewa Rupasinghe wrote:
> I need to automate some GRASS functions in my research work. If there is a
> possibility to build gdal_grass plugin for Windows it is highly
> appreciated. Even the Python scripts that call GRASS functions from
> outside for MS_Windows do not connect with GRASS even though the
> instructions provided in the GRASS wiki is followed. I have posted this
> problem in grass-windows forum and finally advised me to bring the problem
> down to grass-dev list.
And you are positive that the GDAL plugin would help?  The above description
sounds like a more general problem and I don't see any connection to the
missing plugin at all.
Does GRASS itself need the GDAL GRASS plugin at all?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
