[GRASS-dev] To --enable-64bit or not to?
Nikos Alexandris nik at nikosalexandris.net
Sun Dec 30 07:01:05 PST 2012
Nikos Alexandris:
> > Configuring with --enable-64bit results in (working on Kubutnu 12.10, 64
> > bit currently):
Markus Neteler:
> This is what Glynn said:
> On Sat, Dec 19, 2009 at 6:55 AM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> > Isaac Ullah wrote:
> >> My configure options for
> >> grass have 64-bit enabled, so shouldn't that set it up to look for all
> >> 64-bit architecture?
> > AFAICT, the --enable-64bit configure switch only affects AIX, HP-UX,
> > IRIX, and Solaris; it has no effect on Linux.
> So, IMHO when you are on a 64bit Linux box, it will generate 64bit GRASS
> anyway.
O-kay. Then I can ignore the message. Shouldn't the message, though, respect
what is really going on?
Thanks, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121230/b730c0a2/attachment.pgp>
