[GRASS-dev] Re: [GRASS GIS] #1270: Error in Attribute Table Manager
GRASS GIS trac at osgeo.org
Mon Feb 6 07:39:59 EST 2012
 Reporter:  antonioall                         |       Owner:  grass-dev@…
     Type:  defect                             |      Status:  new
 Priority:  critical                           |   Milestone:  6.4.2
Component:  wxGUI                              |     Version:  svn-develbranch6
 Keywords:  wingrass, attribute table manager  |    Platform:  MSWindows Vista
      Cpu:  x86-32                             |
Changes (by hamish):
  * keywords:  wingrass => wingrass, attribute table manager
  * priority:  normal => critical
  * version:  6.4.1 RCs => svn-develbranch6
  * component:  Database => wxGUI
  * milestone:  6.4.1 => 6.4.2
Comment:
 I can reproduce this in 6.5svn nightly build on Windows XP.
 steps as described in the orig report, add a new vector column, edit a
 row, hit submit.
 error is now:
 Error:
 c:\docume~1\hamish\locals~1\temp\tmpuelgf4: Permission denied
 exiting & restarting grass doesn't help, nor does rebooting. (there's not
 zombie dbf.exe afterwards either)
 same error if I try to add a new row or delete and old one.
 ... so it is generally impossible to edit using the attribute table
 manager in wingrass?! (bumping priority)
 suspect the attribute manager is holding the temp file open..
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1270#comment:3>
