[GRASS-dev] Re: [GRASS GIS] #1575: r.horizon bugfix and speedup
GRASS GIS trac at osgeo.org
Tue Feb 14 18:02:22 EST 2012
 Reporter:  sprice       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  svn-trunk
 Keywords:  r.horizon    |    Platform:  All
      Cpu:  OSX/Intel    |
Changes (by hamish):
  * keywords:  => r.horizon
  * platform:  Unspecified => All
  * component:  Default => Raster
Old description:
> I mentioned this on the mailing list, but didn't get a response. So
> here's a more official report:
> I made some tweaks to r.horizon/main.c to almost half its runtime and
> remove a bug. By my tests, it's output is identical to before, but a 219
> minute run has been reduced to 110 minutes. Mostly due to removal of
> unneeded floor() calls. I could use some people to test and make sure I'm
> not introducing any bugs, though.
> Thanks,
> Seth
> --- main.orig   2011-08-14 06:32:49.000000000 -0600
> +++ main.c      2012-02-12 19:20:15.000000000 -0700
> @@ -144,12 +144,15 @@
> /* use G_distance() instead ??!?! */
> double distance(double x1, double x2, double y1, double y2)
> +       double diffX = x1 - x2;
> +       double diffY = y1 - y2;
>     if (ll_correction) {
> -       return DEGREEINMETERS * sqrt(coslatsq * (x1 - x2) * (x1 - x2)
> -                                    + (y1 - y2) * (y1 - y2));
> +       return DEGREEINMETERS * sqrt(coslatsq * diffX * diffX
> +                                    + diffY * diffY);
>     else {
> -       return sqrt((x1 - x2) * (x1 - x2) + (y1 - y2) * (y1 - y2));
> +       return sqrt(diffX * diffX + diffY * diffY);
> @@ -841,36 +844,28 @@
> int new_point()
> -    int iold, jold;
> -    int succes = 1, succes2 = 1;
> -    double sx, sy;
> -    double dx, dy;
> -    iold = ip;
> -    jold = jp;
> +    int iold = ip;
> +    int jold = jp;
> -    while (succes) {
> +    while (1) {
>         yy0 += stepsinangle;
>         xx0 += stepcosangle;
>         /* offset 0.5 cell size to get the right cell i, j */
> -       sx = xx0 * invstepx + offsetx;
> -       sy = yy0 * invstepy + offsety;
> -       ip = (int)sx;
> -       jp = (int)sy;
> +       ip = (int) (xx0 * invstepx + offsetx);
> +       jp = (int) (yy0 * invstepy + offsety);
>         /* test outside of raster */
>         if ((ip < 0) || (ip >= n) || (jp < 0) || (jp >= m))
>             return (3);
>         if ((ip != iold) || (jp != jold)) {
> -           dx = (double)ip *stepx;
> -           dy = (double)jp *stepy;
> +           double dx = (double)ip *stepx;
> +           double dy = (double)jp *stepy;
>             length = distance(xg0, dx, yg0, dy);  /* dist from orig. grid
> point
> to the current grid point */
> -           succes2 = test_low_res();
> -           if (succes2 == 1) {
> +           if (test_low_res() == 1) {
>                 zp = z[jp][ip];
>                 return (1);
> @@ -882,54 +877,44 @@
> int test_low_res()
> -    int iold100, jold100;
> -    double sx, sy;
> -    int delx, dely, mindel;
> -    double zp100, z2, curvature_diff;
> -    iold100 = ip100;
> -    jold100 = jp100;
> -    ip100 = floor(ip / 100.);
> -    jp100 = floor(jp / 100.);
> +    int iold100 = ip100;
> +    int jold100 = jp100;
> +    ip100 = ip * .01;
> +    jp100 = jp * .01;
>     /*test the new position with low resolution */
>     if ((ip100 != iold100) || (jp100 != jold100)) {
>         /* G_debug(3,"%d %d %d %d\n",ip,jp, iold100,jold100); */
>         /*  replace with approximate version
>            curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS));
> +       Code folded into the 'if' statement:
>         curvature_diff = 0.5 * length * length * invEarth;
>         z2 = z_orig + curvature_diff + length * tanh0;
>         zp100 = z100[jp100][ip100];
> +       if (zp100 <= z2) {...
>         /*G_debug(3,"%d %d %lf %lf \n",ip,jp,z2,zp100); */
> -       if (zp100 <= z2)
> +       if (z100[jp100][ip100] <= z_orig + 0.5 * length * length *
> invEarth +
> length * tanh0)
>             /*skip to the next lowres cell */
> -           delx = 32000;
> -           dely = 32000;
> +           int mindel;
> +           int delx = 32000;
> +           int dely = 32000;
> +               double sx = (xx0 * invstepx + offsetx) * .01;
> +               double sy = (yy0 * invstepy + offsety) * .01;
>             if (cosangle > 0.) {
> -               delx =
> -                   floor(fabs
> -                         ((ceil(sx / 100.) - (sx / 100.)) *
> distcosangle));
> +               delx = fabs((ceil(sx) - sx) * distcosangle);
> -           if (cosangle < 0.) {
> -               delx =
> -                   floor(fabs
> -                         ((floor(sx / 100.) - (sx / 100.)) *
> distcosangle));
> +           else if (cosangle < 0.) {
> +               delx = fabs((floor(sx) - sx) * distcosangle);
>             if (sinangle > 0.) {
> -               dely =
> -                   floor(fabs
> -                         ((ceil(sy / 100.) - (sy / 100.)) *
> distsinangle));
> +               dely = fabs((ceil(sy) - sy) * distsinangle);
>             else if (sinangle < 0.) {
> -               dely =
> -                   floor(fabs
> -                         ((floor(jp / 100.) - (sy / 100.)) *
> distsinangle));
> +               dely = fabs((floor(sy) - sy) * distsinangle);
>             mindel = min(delx, dely);
> @@ -953,17 +938,14 @@
> double searching()
> -    double z2;
> -    double curvature_diff;
> -    int succes = 1;
>     if (zp == UNDEFZ)
>         return 0;
>     while (1) {
> -       succes = new_point();
> +    double z2;
> +    double curvature_diff;
> -       if (succes != 1) {
> +       if (new_point() != 1) {
>             break;
New description:
 I mentioned this on the mailing list, but didn't get a response. So here's
 Thanks,
 Seth
Ticket URL: <https://trac.osgeo.org/grass/ticket/1575#comment:2>
