[GRASS-dev] Re: [GRASS GIS] #1534: vector_db_select fails with kwargs
GRASS GIS trac at osgeo.org
Thu Feb 16 19:43:41 EST 2012
  Reporter:  artegion  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  minor     |   Milestone:  6.4.2
 Component:  Python    |     Version:  unspecified
Resolution:  fixed     |    Keywords:  vector_db_select
  Platform:  All       |         Cpu:  Unspecified
Changes (by hamish):
  * keywords:  => vector_db_select
  * priority:  critical => minor
  * status:  new => closed
  * resolution:  => fixed
Comment:
 committed in all branches. a general solution dealing with the root cause
 would be interesting to learn about, but is not needed in this particular
 case.
 AFAICT the function is not used by any of the core grass scripts AFAICT,
 so lowering priority.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1534#comment:2>
