[GRASS-dev] GRASS GIS temporal framework tutorial
Sören Gebbert soerengebbert at googlemail.com
Fri Feb 17 12:33:05 EST 2012
Dear developers,
to allow a detailed discussion about the implementation of the
temporal GIS framework in GRASS
i have decided to make the first part of the promised temporal GIS
tutorial available to interested developers
and GIScientists.
First parts means that the motivation, the methodical conception, the
implementation
and the resulting temporal modules are shortly described. Missing is
the application of the temporal GIS
using the daily temperature and precipitation data from the European
Climate Assessment & Dataset project[1]
for climate change analysis in Europe.
I will need the next two weeks to finish the last part of the
tutorial, since the database is quite large (~50.000 maps).
To get a copy of this unofficial tutorial, please write a mail to me
or to this list and i will send you the first part as pdf file.
Best regards
Soeren
[1] http://eca.knmi.nl/
