[GRASS-dev] Re: [GRASS GIS] #1597: r.topidx ERROR current region resolution
GRASS GIS trac at osgeo.org
Tue Feb 28 15:53:42 EST 2012
 Reporter:  madi      |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.5.0
Component:  Raster    |     Version:  svn-develbranch6
 Keywords:  r.topidx  |    Platform:  Linux
      Cpu:  x86-64    |
Comment(by madi):
 Replying to [comment:11 hamish]:
 > I think the old message could be confusing, the new one is
 > G_fatal_error(_("The current region resolution [%s x %s] is finer "
 >                  "than the input map's resolution [%s x %s]. "
 >                 "The current region resolution must be identical "
 >                 "to, or coarser than, the input map's resolution."),
 > with ew x ns resolution shown with G_format_resolution() instead of %.2f
 which always rounds away the extra digits. Can you test and see if the new
 version gives a more useful error when 'g.region res=20 -a' ?
 > thanks,
 > Hamish
 ERROR: The current region resolution [20 x 20] is finer than the input
 map's resolution [20 x 20.0012809]. The current region resolution must be
 identical to, or coarser than, the input map's resolution.
 This looks way better to me. Thanks a lot.
 madi
Ticket URL: <https://trac.osgeo.org/grass/ticket/1597#comment:12>
