[GRASS-dev] Re: [GRASS GIS] #1526: "Diplay/update attributes" can freeze GUI
GRASS GIS trac at osgeo.org
Tue Jan 3 09:06:52 EST 2012
 Reporter:  artegion  |       Owner:  martinl
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  6.4.2
Component:  wxGUI     |     Version:  6.4.2 RCs
 Keywords:            |    Platform:  MSWindows XP
      Cpu:  x86-64    |
Comment(by martinl):
 Replying to [comment:5 martinl]:
 > Replying to [comment:4 artegion]:
 > > Yes, with 6.5 it works.
 > it's just the coincidence, in G65 simply command which doesn't terminate
 is not called. The SQL statement is checked first and then the command
 (`db.execute sql=`) is launched. The problem is that the process launched
 doesn't terminate in this case.
 probably not related to wxGUI at all, hopefully fixed in r50051. Can you
 confirm it?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:6>
