[GRASS-dev] [GRASS GIS] #1535: winGRASS g.extension.py problems
GRASS GIS trac at osgeo.org
Mon Jan 16 04:37:18 EST 2012
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.2
Component:  wxGUI        |     Version:  6.4.2 RCs
 Keywords:  g.extension  |    Platform:  MSWindows XP
      Cpu:  x86-32       |
 The new Python based g.extension in winGRASS 6.4.2RC3 is creating
 some (packaging?) problems:
  * the "find" button is not linked to python.exe, it asks which
    application to open for g.extension.py (see screenshot)
  * wget is not found (executing g.extension directly):
 (Mon Jan 16 10:32:57 2012)
 g.extension extension=database
 which: wget: unknown command
 GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
 The GRASS program path: [C:/Programmi/GRASS 6.4.SVN] contains a space. The
 build which follows will likely fail.
 The specified install path: [/c/Documents and
 Settings/netelerm.INTRA/.grass6/addons] contains a space. The build which
 The path to your GIS data: [C:\Documents and
 Settings\netelerm.INTRA\Documenti\grassdata] may contain a space. The
 Fetching <database> from GRASS-Addons SVN (be patient)...
 svn: URL 'http://svn.osgeo.org/grass/grass-
 addons/grass6/database/database' doesn't exist
 ERROR: GRASS Add-on database not found in repository or no network
 connection or another problem
 (Mon Jan 16 10:33:08 2012) Comando terminato (10 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1535>
