[GRASS-dev] [GRASS GIS] #1538: wxGUI: Common raster formats importer python error for single file
GRASS GIS trac at osgeo.org
Mon Jan 16 17:33:54 EST 2012
 Reporter:  neteler  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.4.2
Component:  wxGUI    |     Version:  6.4.2 RCs
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
 When importing with File -> Import -> Common raster formats
 -> File (directory works fine) ->
 /home/neteler/data/satellite/landsat_etna/srtm_etna_90m_UTM33.tif
 I get this error
   File "/usr/lib64/python2.7/site-
 packages/wx-2.8-gtk2-unicode/wx/lib/filebrowsebutton.py",
 line 140, in OnChanged
 self.changeCallback(evt)
   File "/home/neteler/grass64/dist.x86_64-unknown-linux-
 gnu/etc/wxpython/gui_modules/gselect.py", line 1439, in
 OnSetDsn
 self._reloadLayers()
 gnu/etc/wxpython/gui_modules/gselect.py", line 1457, in
 _reloadLayers
 grassName = utils.GetValidLayerName(baseName.split('.',
 -1)[0])
 gnu/etc/wxpython/gui_modules/utils.py", line 188, in
 GetValidLayerName
 if not (retName[0] >= 'A' and retName[0] <= 'Z') and \
 IndexError
 string index out of range
 (Mon Jan 16 15:41:44 2012)
 r.in.gdal
 input=/home/neteler/data/satellite/landsat_etna/srtm_etna_90m_UTM33.tif
 output=srtm_etna_90m_UTM33
 Projection of input dataset and current location appear to match
 r.in.gdal complete. Raster map <srtm_etna_90m_UTM33> created.
 (Mon Jan 16 15:41:45 2012) Command finished (0 sec)
 The dialog crashes but the map is imported.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1538>
