[GRASS-dev] Re: [GRASS GIS] #1073: G_fatal_error segfault outside of GRASS session
GRASS GIS trac at osgeo.org
Wed Jan 18 05:46:30 EST 2012
 Reporter:  kyngchaos        |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  6.4.0
Component:  LibGIS           |     Version:  6.4.0 RCs
 Keywords:  G_fatal_error()  |    Platform:  MacOSX
      Cpu:  OSX/Intel        |
Comment(by glynn):
 Replying to [comment:2 hamish]:
 > I get a complaint about "error while loading shared libraries, cannot
 open shared object file: No such file or directory" if I try to run a C
 module outside of a GRASS session.
 That's to be expected; the loader needs LD_LIBRARY_PATH (DYLD_LIBRARY_PATH
 on OSX, PATH on Windows) to be set in order to locate the GRASS libraries.
 To check for this specific issue, either set PATH and LD_LIBRARY_PATH
 (etc) manually, or start a GRASS session then manually unset GISBASE and
 GISRC with:
 export -n GISBASE GISRC
Ticket URL: <https://trac.osgeo.org/grass/ticket/1073#comment:3>
