[GRASS-dev] Map_info with_z
Hamish hamish_b at yahoo.com
Tue Jan 24 20:41:08 EST 2012
Martin:
> > Map->plus.spidx_with_z (Plus_head) -> spatial index
Markus Metz:
> That is coming from GRASS 5 and used as a safety check that the
> spatial index has the same dimensions like the coordinates.
> It can probably be removed.
please don't remove safety checks [if they are still meaningful].
they are there for a (very good) reason.
thanks,
Hamish
