[GRASS-dev] v.info: projection info wrong
Hamish
hamish_b at yahoo.com
Fri Jan 27 02:38:27 EST 2012
Markus Neteler wrote:
> GRASS 6.4.2svn
> (piemonte_utm32_wgs84):/grassdata > v.info beni_urbanistici
> | Location: piemonte_utm32_wgs84
> | Projection: x,y (zone 0)
> --> x,y (zone 0)?
> GRASS 6.4.2svn (piemonte_utm32_wgs84):/grassdata > g.region -p
> projection: 1 (UTM)
> zone: 32
> datum: wgs84
> ellipsoid: wgs84
I know where the zone 0 comes from (for this map was never set
in vector/$MAP/head), but the "x,y" confuses me a little.
what does your piemonte_utm32_wgs84/PERMANENT/PROJ_INFO say
on the top 'name:' line? it should be UTM. If not, how did
you create that location? Was it created as x,y then changed
to UTM by some manual method?
Hamish
