[GRASS-dev] [GRASS GIS] #1683: error message v.add.col on MacOSX
GRASS GIS trac at osgeo.org
Wed Jul 4 05:16:52 PDT 2012
 Reporter:  jradinger      |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:  6.4.3
Component:  Shell Scripts  |     Version:  svn-develbranch6
 Keywords:  v.db.addcol    |    Platform:  All
      Cpu:  Unspecified    |
Comment(by neteler):
 Replying to [comment:5 hamish]:
 > The immediate culprit is `eval g.gisenv`,
 > The underlying fix is to not store the addon path as a GRASS variable,
 store it as a shell environment variable -- and only a shell variable --
 instead.
 > Remove it from the g.gisenv list with:
 > g.gisenv set="ADDON_PATH="
 > then v.db.addcol should be happy.
 Backported to 6.4.svn, too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1683#comment:8>
