[GRASS-dev] [GRASS GIS] #1689: weird import with r.in.gdal
GRASS GIS trac at osgeo.org
Fri Jul 20 04:45:35 PDT 2012
 Reporter:  madi       |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:  6.4.3
Component:  Raster     |     Version:  svn-releasebranch64
 Keywords:  r.in.gdal  |    Platform:  Linux
      Cpu:  x86-64     |
 Hi all,
 I pointed this out already in ML, but in the same thread there were many
 topics so that i better separate this one in a dedicated ticket.
 I have generated a vrt file by this procedure
 http://grass.osgeo.org/wiki/Large_raster_data_processing and imported it
 into grass with the following commands:
 r.in.gdal input="/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt" output="mosaic"
 and
 r.external -r input="/forest/ASTER-GDEM/Dem_lzw/mosaic.vrt"
 output="mosaic2"
 Then, comparing mosaic and mosaic2, i get:
 GRASS 6.4.3svn (ASTER_GDEM):~ > r.info map=mosaic
  | Layer:    mosaic                         Date: Tue Jul 17 17:57:31 2012
  | Mapset:   PERMANENT                      Login of Creator: leomarg
  | DataBase: /forest/GRASS/grassdata
  | Title:     ( mosaic )
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 6518
  |   Data Type:    CELL
  |   Rows:         140401
  |   Columns:      198001
  |   Total Cells:  27799538401
  |        Projection: Latitude-Longitude
  |            N: 72:00:00.5N    S: 32:59:59.5N   Res: 0:00:01
  |            E: 44:00:00.5E    W: 11:00:00.5W   Res: 0:00:01
  |   Range of data:    min = -9999  max = 6518
  |   Data Description:
  |    generated by r.in.gdal
  |   Comments:
 output="mosa\   |
  |    ic"
 GRASS 6.4.3svn (ASTER_GDEM):~ > r.info map=mosaic2
  | Layer:    mosaic2                        Date: Wed Jul 18 10:54:37 2012
  | Title:     ( mosaic2 )
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 0
  |   Data Type:    CELL
  |   Rows:         140401
  |   Columns:      198001
  |   Data Description:
  |    generated by r.external
  |   Comments:
 output="\   |
  |    mosaic2"
 The problem is that with r.in.gdal, the map is shrinked, while the map
 produced by r.external is correct. See the attached pictures.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1689>
