[GRASS-dev] po-strings f=?iso-8859-1?B?/A==?=r r.mapcalc
Sat Jul 21 09:13:44 PDT 2012
Maris Nartiss wrote:
> > From the C side, using:
> >         const char *help_text = _("...");
> > inside main() would work. That may be preferable to putting a large
> > string literal inside the fputs() call.
> Just my curiosity as I'm not a good programmer (more coder than
> programmer) - why using large string literal in fputs is so bad idea?
Legibility.
