[GRASS-dev] grass-dev Digest, Vol 77, Issue 37
Michael Barton michael.barton at asu.edu
Wed Jul 25 14:43:54 PDT 2012
This is where it bombs. If I set self.showChoice so that this doesn't execute, GRASS starts up fine
"/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gui_core/ghelp.py", line 81, in __init__
    self.searchChoice.SetItems(self.cmdPrompt.GetCommandItems())
Michael
On Jul 25, 2012, at 2:20 PM, <grass-dev-request at lists.osgeo.org>
 <grass-dev-request at lists.osgeo.org> wrote:
> From: Michael Barton <michael.barton at asu.edu>
> Date: July 25, 2012 2:12:39 PM MST
> To: Kyngesburye William <kyngchaos at kyngchaos.com>, <grass-dev at lists.osgeo.org>
> Subject: Re: [GRASS-dev] GRASS 6 REALLY IS broken on Mac
> More tests.
> If I delete .grassrc6 and start GRASS, it opens fine after asking for a GISDBASE location. But if I try to start it again, it errors out with the error below.
> I suspect there is something wrong with a configuration file path. It has been changed and the new file is not being created
> Michael
> On Jul 25, 2012, at 2:03 PM, Michael Barton wrote:
>> Something installed another Python version without my knowledge. Getting rid of this solved the problem.
>> Michael
>> On Jul 25, 2012, at 1:22 PM, Michael Barton wrote:
>>> I'm recompiling GRASS binaries and found that GRASS 6 is broken on the Mac. This is true for the current svn version I just updated and for the version I compiled 28 June--both release branch and dev branch. I updated all frameworks today, but I don't know if I tested the 28 June version of GRASS 6 after I compiled it. So I don't know if it is in the updated frameworks (updated on 29 June) or in the GRASS code. GRASS 7 works fine. When I try to launch GRASS 6, I get the following error after selecting a mapset and clicking 'start grass'.
>>> GRASS 6.4.3svn (Spearfish60_test):~ > Traceback (most recent call last):
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 139, in <module>
>>>     sys.exit(main())
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 132, in main
>>>     app = GMApp(workspaceFile)
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 45, in __init__
>>>     wx.App.__init__(self, False)
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 7981, in __init__
>>>     self._BootstrapApp()
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 7555, in _BootstrapApp
>>>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py", line 78, in OnInit
>>>     workspace = self.workspaceFile)
>>>   File "/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin10.8.0/etc/wxpython/lmgr/frame.py", line 108, in __init__
>>>     self.notebook  = self._createNoteBook()
>>>   File "/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin10.8.0/etc/wxpython/lmgr/frame.py", line 257, in _createNoteBook
>>>     self.goutput = GMConsole(self)
>>>   File "/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin10.8.0/etc/wxpython/gui_core/goutput.py", line 240, in __init__
>>>     self.MakeSearchPaneContent(self.searchPane.GetPane())
>>>   File "/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin10.8.0/etc/wxpython/gui_core/goutput.py", line 356, in MakeSearchPaneContent
>>>     self.search = SearchModuleWindow(parent = pane, cmdPrompt = self.cmdPrompt)
>>>   File "/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin10.8.0/etc/wxpython/gui_core/ghelp.py", line 81, in __init__
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 11997, in SetItems
>>>     self.AppendItems(items)
>>>   File "/Applications/GRASS/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py", line 11859, in AppendItems
>>>     return _core_.ItemContainer_AppendItems(*args, **kwargs)
>>> UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 100: ordinal not in range(128)
>>> I have not changed my python or wxpython installation since the last time I had a working GRASS 6 (earlier in June).
>>> Michael
>>> _____________________
>>> C. Michael Barton
>>> Visiting Scientist, Integrated Science Program
>>> National Center for Atmospheric Research &
>>> University Corporation for Atmospheric Research
>>> 303-497-2889 (voice)
>>> Director, Center for Social Dynamics & Complexity
>>> Professor of Anthropology, School of Human Evolution & Social Change
>>> Arizona State University
>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> C. Michael Barton
> C. Michael Barton
C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120725/3bcb8c76/attachment-0001.html>
