[GRASS-dev] more on locale problem
William Kyngesburye woklist at kyngchaos.com
Thu Jul 26 06:26:47 PDT 2012
As you mentioned Michael, there was discussion of this problem a few times in the past.
The problem setting is not LANG, though, it's LC_CTYPE.  The system is somehow setting that to "UTF-8", and Python checks LC_CTYPE (and LC_ALL next) before it checks LANG, so setting LANG in GRASS won't help, as Agustin found.
On Jul 26, 2012, at 5:03 AM, Agustin Angel Diez Castillo wrote:
> Michael and others,
> Michael's 6.4.3 menus aren't working here, I did try adding
> en_US.UTF-8
> to .grassrc6 but the complaints are the same
> ERROR: unknown locale: UTF-8
> 2012-07-26 11:56:43.011 Python[1916:e0f] CFURLCreateWithString was passed this invalid URL string: '/System/Library/CoreServices/CommonCocoaPanels.bundle' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
> by the way my system preferences are set to english but the region is set to Spain.
> cli is working
> As you know in R the language is forced with
> defaults write org.R-project.R force.LANG en_US.UTF-8
> Is there something similar in GRASS?
> A
> On Thursday, July 26, 2012 08:16 CEST, Michael Barton <Michael.Barton at asu.edu> wrote:
>> So I am now completely baffled as to why GRASS is not working on my colleague's computer. it is a pretty new MacBook (last 6 months) and he has not installed much on it--Office, Mendeley. It is running the most current version of Lion (10.7.4).
>> There are repeated problems with locale on it. Here is an example that works fine on my computer also running Lion.
>> import locale
>> locale.getdefaultlocale()
>> Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py", line 496, in getdefaultlocale
>> File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/locale.py", line 428, in _parse_localename
>> ValueError: unknown locale: UTF-8
>> I don't know where it is getting UTF-8. The GUI code in GRASS calls the language en_ES.UTF-8, but this is running Python outside of GRASS. I've tried setting locale to es_EN, and to C. But we still get this error when locale.getdefaultlocale() is run in wx GUI.
>> Any ideas?????
>> Michael
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
