[GRASS-dev] Report #2, GSoC Image Segmentation
Eric Momsen
eric.momsen at gmail.com
Fri Jun 1 22:14:08 PDT 2012
Hi all,
Completed:
I spent the week learning and implementing the "segmentation library" which
deals with tiling large rasters to balance memory constraints with disk
I/O. It is totally different from image segmentation, the task of the
program, so hopefully the dual meaning of the word won't cause too many
headaches! There is a lot of good information in the GRASS programmer's
manual, that has been good reading.
The data I/O portion is coded, using both imagery groups and segmentation
data storage. It compiled today, but quits half way through. Hopefully
I'm just missing some small syntax error.
Tasks for next week:
Get I/O to work.
Write the basic image segmentation algorithm.
Blocking:
Nothing yet, there are some bug(s?) preventing the program from running.
But I've just now figured out where the problem is and need some time to
continue looking for the solution.
-Eric
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120602/bee2b5cd/attachment.html>
