[GRASS-dev] [GRASS GIS] #1630: g.gui error on startup of March 24th 6.4.3 snapshot
trac at osgeo.org
Wed Jun 13 10:34:19 PDT 2012
Reporter: epatton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: wxGUI, startup | Platform: Linux
Cpu: x86-64 |
Comment(by grruddy):
I am getting a similar error. I installed GRASS 6.4.2 on a SLES 10 system
with no problem. Now, I am attempting to install GRASS 6.4.2 on a RHEL 6
system, but am getting the following error upon startup.
GRASS 6.4.2 > Traceback (most recent call last):
File
"/usr/local/intel64/nehalem/gcc/grass-6.4.2/grass-6.4.2/etc/wxpython/wxgui.py",
line 1721, in <module>
sys.exit(main())
File
line 1714, in main
app = GMApp(workspaceFile)
File
line 1605, in __init__
wx.App.__init__(self, False)
File "/usr/local/wx/wxWidgets-2.8.12.1/site-
packages/lib64/python/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in
__init__
self._BootstrapApp()
packages/lib64/python/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in
_BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File
line 1657, in OnInit
workspace = self.workspaceFile)
File
line 128, in __init__
self._createMenuBar()
File
line 232, in _createMenuBar
self.menubar = menu.Menu(parent = self, data = menudata.ManagerData())
File
"/usr/local/intel64/nehalem/gcc/grass-6.4.2/grass-6.4.2/etc/wxpython/gui_modules/menudata.py",
line 202, in __init__
MenuData.__init__(self, filename)
File
line 49, in __init__
self.tree = etree.parse(filename)
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 862, in parse
tree.parse(source, parser)
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 586, in parse
parser.feed(data)
File "/usr/lib64/python2.6/xml/etree/ElementTree.py", line 1245, in feed
self._parser.Parse(data, 0)
SystemError: Objects/listobject.c:126: bad argument to internal function
The only difference I can identify is that I am using GCC 4.7.0 and that
my wxPython installation is installed in a seperate site-packages location
than the system version of Python 2.6.6. This seperate site-packages
location has been added to the PYTHONPATH, and the initial launch page
appears allowing me to select my Location and mapset. However, once the
splash screen appears, this error is triggered. Any ideas what may be
causing this?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1630#comment:2>
