[GRASS-dev] Usage of size_t
Markus Metz markus.metz.giswork at googlemail.com
Thu Jun 21 09:14:05 PDT 2012
On Thu, Jun 21, 2012 at 5:16 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hello,
> I'm moving size_t topic from user to dev list.
> As I understand, size_t should be used also for number of rows and
> number of columns of a map. But for example Rast_window_{rows,cols}
> returns int. So will this be also changed/fixed to size_t?
Considering current hardware, we struggle to support maps with
2147483647 (the maximum value representable by a 32-bit integer;
Glynn's previous answer) cells = rows * columns. Therefore I guess
that for the time being int is fine as data type for rows and columns.
Supporting 2147483647 rows x 2147483647 columns is still a far way to
go. Type size_t should be used for rows * columns * sizeof(some data)
when allocating memory, and type off_t should be used for rows *
columns * sizeof(some data) for disk IO. I would just cast as
suggested by Glynn.
> Note that some instances of using int instead of size_t can be
> identified by GCC warning option -Wsign-conversion. It marks usage of
> int as an argument of malloc/G_calloc/... or usage of int for
> iterating C++ STL containers.
The number of rows and columns should always be non-negative, thus no
worries about sign conversion.
Also note that when calling e.g. Rast_northing_to_row() which returns
the row number, not the number of rows, the resulting row can be
negative and must be treated as double or casted to some signed
integer, not a potentially unsigned size_t.
Markus M
> Vaclav
> From topic "NVIZ can't allocate enough memory" on [GRASS-user]:
>> From: Glynn Clements <glynn at gclements.plus.com>
>> Date: Tue, Jun 12, 2012 at 5:23 AM
>> Subject: Re: [GRASS-user] NVIZ can't allocate enough memory
>> To: Daniel Lee <lee at isi-solutions.org>
>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>> Daniel Lee wrote:
>>> ERROR: G_malloc: unable to allocate 18446744071974792324 bytes at gsds.c:575
>> 18446744071974792324 = 0xffffffff9899ac84
>>> Does anybody know what could be the problem? If I'm interpreting the bytes
>>> correctly, that'd be about 10^10 gigabytes, which several orders of
>>> magnitude larger than the rasters involved. Thanks!
>> A calculation has overflowed the range of a signed 32-bit integer
>> resulting in a negative value. This value has then been converted to a
>> signed 64-bit integer, and then to an unsigned 64-bit integer.
>>> Here's the output of g.region:
>>> rows:       32001
>>> cols:       20001
>>> cells:      640052001
>> At 4 bytes per cell, 640052001 cells = 2560208004 bytes.
>> 2560208004 = 0x9899ac84
>> The maximum value representable by a 32-bit integer is 0x7fffffff =
>> 2147483647.
>> Using an unsigned integer would eliminate the problem in this
>> particular case, but the region wouldn't need to be much larger in
>> order for that to be insufficient (specifically, 32001 x 33553 would
>> overflow).
>> The correct solution is to use "size_t" rather than "int". E.g. for
>> this specific case:
>> --- gsds.c      (revision 52015)
>> +++ gsds.c      (working copy)
>> @@ -481,7 +481,8 @@
>>  int gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
>>     dataset *ds;
>> -    int i, siz = 1;
>> +    int i;
>> +    size_t siz = 1;
>>     if ((ds = get_dataset(id))) {
>> More generally, it's important that the conversion comes before the
>> mulitply; e.g.:
>>        size_t cells = (size_t) rows * cols;
>> will work but:
>>        size_t cells = rows * cols;
>> won't; the calculation will be perfomed using "int", overflow, then
>> the overflowed result will be promoted.
>> However: the number of instances of this particular issue in the GRASS
>> source code is probably somewhere between "dozens" and "hundreds", and
>> there's no systematic way to identify them. Running test cases with a
>> region of >= 2^32 cells (or even >= 2^29 cells, i.e. >= 2^31 bytes at
>> 4 bytes per cell) would find a lot of them, but it requires a 64-bit
>> system with plenty of RAM, and it's going to be slow.
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
