[GRASS-dev] pthreads in r.mapcalc slower than without
Hamish
hamish_b at yahoo.com
Sat Jun 23 19:49:40 PDT 2012
I've just been running some benchmarks for r.mapcalc
to try and find the best method for parallelizing
a script / best way to minimize overheads.
I'd like to understand where it is useful to combine
expressions into a single r.mapcalc process, and
where it isn't, and what sort of mapcalc expressions
can best take advantage of pthreads support, and
which are not good matches for it.
also, as with some OpenMP experiments, if it makes
sense to parallelize by row (given a target column
length of 1000-3000 cells), or by some other way
(e.g. for a 1000 row tall raster spawn 4 x 250row
each threads)
summary of results: r.mapcalc built without pthread
support was the fastest for my test case. When built
with pthread support, using WORKERS=1 was the fastest option (default is 8)*. executing r.mapcalc
as three different processes was the fastest of all.
1-worker grass7 x3 processes was faster than
grass6.5svn.
[*] note that even with r.mapcalc built without
pthreads (make clean r.mapcalc dir + edited r.mapcalc
Makefile) it still uses more than one CPU core.
maybe because of lib/gis/counter.c(?)
test case: r.blend's 3-in-1 r.mapcalc expression,
with a region of rows: 2355, cols: 3045
test machine: 6-core CPU (full cores, not hyperthreaded ones)
timing results: follow.
thanks for any ideas,
Hamish
(hoping linewrap doesn't mess it up)
# grass7, spearfish
FIRST=elevation.10m
SECOND=aspect
PERCENT=35
OUTPUT=tmp.mpclc
g.region n=4323650 s=4318940 w=289020 e=295110 res=2
for w in `seq 14` ; do
echo -n "Workers: $w"
time WORKERS=$w r.mapcalc "$OUTPUT.r = r#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * r#$SECOND ; \
$OUTPUT.g = g#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * g#$SECOND ; \
$OUTPUT.b = b#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * b#$SECOND" \
--overwrite --quiet
echo
done
# three replicates shown columnwise
Workers: 1
real 0m5.711s real 0m5.716s real 0m5.672s
user 0m7.544s user 0m7.552s user 0m7.596s
sys 0m0.332s sys 0m0.348s sys 0m0.260s
Workers: 2
real 0m5.987s real 0m6.142s real 0m5.976s
user 0m7.028s user 0m7.224s user 0m7.028s
sys 0m0.584s sys 0m0.596s sys 0m0.560s
Workers: 3
real 0m6.300s real 0m6.180s real 0m6.184s
user 0m7.512s user 0m7.408s user 0m7.488s
sys 0m0.620s sys 0m0.612s sys 0m0.604s
Workers: 4
real 0m6.693s real 0m6.605s real 0m6.642s
user 0m7.780s user 0m7.632s user 0m7.612s
sys 0m0.856s sys 0m0.840s sys 0m0.888s
Workers: 5
real 0m6.279s real 0m6.203s real 0m6.246s
user 0m7.496s user 0m7.528s user 0m7.484s
sys 0m0.996s sys 0m0.920s sys 0m0.972s
Workers: 6
real 0m6.231s real 0m6.378s real 0m6.180s
user 0m7.588s user 0m7.712s user 0m7.656s
sys 0m1.028s sys 0m0.980s sys 0m0.924s
Workers: 7
real 0m6.080s real 0m6.114s real 0m6.148s
user 0m7.616s user 0m7.588s user 0m7.704s
sys 0m1.040s sys 0m1.096s sys 0m1.016s
Workers: 8
real 0m6.181s real 0m6.294s real 0m6.251s
user 0m7.700s user 0m7.820s user 0m7.756s
sys 0m1.100s sys 0m1.096s sys 0m1.140s
Workers: 9
real 0m6.307s real 0m6.263s real 0m6.269s
user 0m7.772s user 0m7.784s user 0m7.732s
sys 0m1.196s sys 0m1.160s sys 0m1.172s
Workers: 10
real 0m6.333s real 0m6.333s real 0m6.278s
user 0m7.720s user 0m7.696s user 0m7.752s
sys 0m1.272s sys 0m1.304s sys 0m1.204s
Workers: 11
real 0m6.315s real 0m6.322s real 0m6.292s
user 0m7.820s user 0m7.760s user 0m7.820s
sys 0m1.192s sys 0m1.232s sys 0m1.160s
Workers: 12
real 0m6.275s real 0m6.307s real 0m6.322s
user 0m7.724s user 0m7.732s user 0m7.824s
sys 0m1.240s sys 0m1.256s sys 0m1.192s
Workers: 13
real 0m6.324s real 0m6.316s real 0m6.301s
user 0m7.816s user 0m7.852s user 0m7.784s
sys 0m1.204s sys 0m1.176s sys 0m1.192s
Workers: 14
real 0m6.333s real 0m6.316s real 0m6.291s
user 0m7.668s user 0m7.796s user 0m7.840s
sys 0m1.336s sys 0m1.224s sys 0m1.156s
# split combined mapcalc expression into three different processes
export WORKERS=1
export GRASS_OVERWRITE=1
export GRASS_VERBOSE=0
time (
r.mapcalc "$OUTPUT.r = r#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * r#$SECOND"
r.mapcalc "$OUTPUT.g = g#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * g#$SECOND"
r.mapcalc "$OUTPUT.b = b#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * b#$SECOND"
real 0m5.650s real 0m5.700s real 0m5.727s
user 0m7.428s user 0m7.596s user 0m7.468s
sys 0m0.392s sys 0m0.312s sys 0m0.432s
# shell backgrounding as parallelization method:
export WORKERS=1
time (
r.mapcalc "$OUTPUT.r = r#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * r#$SECOND" &
r.mapcalc "$OUTPUT.g = g#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * g#$SECOND" &
r.mapcalc "$OUTPUT.b = b#$FIRST * $PERCENT/100.0 + (1.0 - $PERCENT/100.0) * b#$SECOND" &
wait
real 0m2.110s real 0m2.115s real 0m2.088s
user 0m8.121s user 0m8.241s user 0m8.229s
sys 0m0.544s sys 0m0.476s sys 0m0.408s
#same, but with r.mapcalc recompiled without pthreads libs
export WORKERS=1
real 0m2.100s real 0m2.086s real 0m2.095s
user 0m8.049s user 0m8.037s user 0m8.093s
sys 0m0.528s sys 0m0.472s sys 0m0.468s
export WORKERS=8
time (
wait
real 0m2.455s real 0m2.466s real 0m2.457s
user 0m8.229s user 0m8.125s user 0m8.225s
sys 0m0.940s sys 0m1.072s sys 0m0.956s
#same, for grass 6.5svn:
real 0m3.805s real 0m3.651s real 0m3.689s
user 0m10.481s user 0m10.533s user 0m10.557s
sys 0m0.484s sys 0m0.372s sys 0m0.400s
