[GRASS-dev] [GRASS GIS] #1679: d.histogram fails to start
trac at osgeo.org
Mon Jun 25 14:23:34 PDT 2012
Reporter: JRadinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Display | Version: svn-develbranch6
Keywords: d.histogram | Platform: MacOSX
Cpu: Unspecified |
Changes (by hamish):
* cc: r52187 (removed)
* keywords: => d.histogram
Comment:
The d.* modules are not intended to be run from the GUI command console,
nor from the OSX desktop.
You need to start an xmon from the GRASS Terminal window's command prompt
(d.mon x0), then run it. Or start the histogram from the "analyze map"
button which is to the right of the right-most magnifying glass icon in
the Map Display GUI window.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1679#comment:1>
