[GRASS-dev] PCA question
Nikos Alexandris
nik at nikosalexandris.net
Tue Jun 26 06:31:17 PDT 2012
Nikos:
> > Which resolution is to be enhanced? The geometric? Is it meant
> > to keep PC1 and mix it with the rest, or keep the Pan and throw
> > away PC1?
> > Principal Component 1 will contain the highest variance of
> > your input data -- which, in fact, is a composition of different
> > amount of information originated from all input bands. If you
> > throw that away you are left with a dataset which is likely to
> > be useless!
Hamish:
> (not talking about pan-sharpening, but in general,)
> how about the situation where you have a map data
( we are talking about multi-dimensional data, right? )
> which is loudly dominated by a signal, and you want to try and remove that
> loud signal so that you can look at the subtle variations caused by a
> different source that the loud signal had been masking?
Yes, this _can_ be a perfect use-case.
Especially if the presence of the feature in question, is in at least one or
in some of the input dimensions near/close to zero. This last statement is
based on Pielou's (flawless explanation of how PCA works) [1] and own
experiences [2].
A separation/isolation attempt of the feature in question from dominant
variances will be "supported". The "loud" signal would be channeled among the
first few PCs and the "subtle variations" _could_ then be more evident in some
of the higher order components.
All in all, one has to look at the numbers -- drawing conclusions from the PC
images is not safe!
> is removing PC1 then back-inverting a suitable method for that sort of task?
Short answer: yes, it can be, but back-inverting might not be necessary!
Longer story: if the "subtle variations" (featueres of low(er) variance,
rather homogenous stuff) are, as expected, more evident (read: enhanced as
compared to the original data set) in some of the higher order components, why
bother to back-invert? Supervised classification techniques can directly
operate on selected PCs and attempt to extract whatever is of your interest.
More on the subject of back-inverting -- quotting from Dr. Koutsias paper:
"A critical issue in the back-transformation process is the
amount of information taken from each PC axis. The original
spectral pattern of the satellite image is modified to a degree that
depends on the amount of the information taken from each PC axis."
In this work (mapping burned areas), "back-transformation coefficients", in the
range of 0 to 1, were worked-out in order to 'grep' specific percentages (0 to
100%) from each of the produced PCs and channel them back (via inverse-PCA) to
a data set _similar_ to the original one, though different to the extent of the
removed information (excluded PC).
> or is there another more suitable method?
Dunno more... :-(
Kindest regards, Nikos
[1] Book: Pielou, E. C. The interpretation of ecological data: a primer on
classification and ordination Wiley, New York, 1984
[2] <Dissertation: Burned area mapping via non-centered PCA using Public
Domain Data and Free Open Source Software Institut für Forstökonomie, Fakultät
für Forst- und Umweltwissenschaften, Albert-Ludwigs-Universität Freiburg,
2011>
[3] <Koutsias, N.; Mallinis, G. & Karteris, M. A forward/backward principal
component analysis of Landsat-7 ETM+ data to enhance the spectral signal of
burnt surfaces ISPRS Journal of Photogrammetry and Remote Sensing, 2009, 64,
37>
