[GRASS-dev] [GRASS GIS] #1604: WXGUI regression. d.vect by default incorrectly says that it's displaying vectors from all layers
GRASS GIS trac at osgeo.org
Sun Mar 11 04:28:28 EDT 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  6.4.2
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 Steps to reproduce:
  * add a vector map with more than one layer
  * go to properties
  * check, that "Selection" -> "Layer" says "-1" (as by default)
  * check, that only features from "Layer" 1 are rendered, as there's no
 "layer=-1" parameter used when executing d.vect.
 Workaround - change "Layer" to 1 and back to "-1" to add "layer" option to
 executed command.
 This is a regression, as in 6.4.0 WXGUI was working correctly -> it was
 displaying by default only layer 1 and also features where rendered only
 from layer 1.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1604>
