[GRASS-dev] [GRASS GIS] #1612: r.mapcalc won't do anything
GRASS GIS trac at osgeo.org
Mon Mar 12 05:44:24 EDT 2012
 Reporter:  berobispo  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.3
Component:  Default    |     Version:  6.4.2
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 Hi!
 just have installed MacGrass 6.4.2 (from Kyngchaos). When I try to use
 r.mapcalc, nothing is being calcluated, instead this error message shows
 up:
 r.mapcalc rivers = if(accu at PERMANENT>6)
 dyld: Library not loaded: /usr/lib/libedit.3.dylib
   Referenced from:
 /Applications/GRASS-6.4.app/Contents/MacOS/bin/r.mapcalc
   Reason: image not found
 I have installed all required frameworks.
 Running the wxpython GUI on a macbook 2,1 with Snow Leopard 10.6.8
 (updated)
 How can I "load" that library? The WinGrass version's r.mapcalc did handle
 the expression... but had some major issues with attribute tables so I
 thought about giving MacGrass a try. Unfortunately, no UNIX experience,
 maybe somebody can point me in the right direction
Ticket URL: <http://trac.osgeo.org/grass/ticket/1612>
