[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
GRASS GIS trac at osgeo.org
Tue Mar 13 13:12:11 EDT 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  Vector       |     Version:  6.4.2
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 When running v.transform with zshift option to create a 3D map, there are
 three issues:
  * GUI layout has changed since 6.4.0 (this is no-no for a stable release)
  * when executed from WXGUI, there's a simple crash
  * when executed from tcltk GUI, it is hanging till dbf.exe process is
 killed
  * resulting map is a 2D instead of 3D, as in 6.4.0
 Command used to test:
 v.transform input=Dores_punkti_10k at bulba output=dores_punkti_3d
 table=Dores_punkti_10k columns=zshift:h
 Crash info:
 Problem Event Name:     APPCRASH
   Application Name:     v.transform.exe
   Application Version:  0.0.0.0
   Application Timestamp:        4f410e6e
   Fault Module Name:    ntdll.dll
   Fault Module Version: 6.0.6002.18541
   Fault Module Timestamp:       4ec3e3d5
   Exception Code:       c0000005
   Exception Offset:     00067daa
   OS Version:   6.0.6002.2.2.0.256.6
   Locale ID:    1062
   Additional Information 1:     8ed9
   Additional Information 2:     802ed84e5e7e3c072dd89c95c6b2c33f
   Additional Information 3:     d541
   Additional Information 4:     78eb81a857c38b14810170133ea43f63
 Marking as major, as existing functionality was broken in a stable
 release.
 2d/3d issue is most likely introduced by Martin in r45103
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615>
