[GRASS-dev] Re: [GRASS-user] NetCDF rotated pole
Michael Barton Michael.Barton at asu.edu
Tue Mar 20 18:12:48 EDT 2012
Edwardo,
I am attaching a PDF and RTF of the workflow I used to import paleocurrent data from a NetCDF file with rotated poles. While it may not exactly match your file, it should give you an idea of how to proceed. Let me know how it comes out.
Name: processing workflow for current data.pdf
Type: application/pdf
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20120320/4077390e/processingworkflowforcurrentdata-0001.pdf
Name: processing workflow for current data.rtf
Type: text/rtf
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20120320/4077390e/processingworkflowforcurrentdata-0001.rtf
Michael
On Mar 20, 2012, at 6:18 AM, Eduardo Klein wrote:
> Thanks Michael, your advice will be much appreciated!.
> Saludos, EKS
> On 03/19/2012 04:39 PM, Michael Barton wrote:
>> I'm at NCAR right now and I'm doing that very thing today in fact.
>> Once I have an answer as to the difference between TLAT and ULAT, and TLONG and ULONG within the NetCDF files, I'll be able to give you a full work flow for this.
>> Michael
>> On Mar 19, 2012, at 2:44 PM,<grass-user-request at lists.osgeo.org>  wrote:
>>> Message: 3
>>> Date: Mon, 19 Mar 2012 13:20:33 -0430
>>> From: Eduardo Klein<eklein at usb.ve>
>>> Subject: [GRASS-user] NetCDF rotated pole
>>> To: grass-user at lists.osgeo.org
>>> Message-ID:<4F6771E9.2080301 at usb.ve>
>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>> Hi,
>>> Is there any way to read a NetCDF file which has a rotated pole Mercator
>>> projection and have it inside GRASS with the North pole at North?
>>> I'm trying to use AVISO SSH products on GRASS 6.4.1 and gdal 1.8.0
>>> Thanks!
>>> Eduardo Klein
>>> Lab Sensores Remotos e
>>> Instituto de Tecnolog?a y Ciencias Marinas
>>> Universidad Sim?n Bol?var
>>> Caracas, Venezuela
>>> ph (58) (212) 906-3111 ext 6700
>>> fax (58) (212( 906-3111 ext 6701
>> _____________________
>> C. Michael Barton
>> Visiting Scientist, Integrated Science Program
>> National Center for Atmospheric Research&
>> University Corporation for Atmospheric Research
>> 303-497-2889 (voice)
>> Director, Center for Social Dynamics&  Complexity
>> Professor of Anthropology, School of Human Evolution&  Social Change
>> Arizona State University
>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> Eduardo Klein
> Instituto de Tecnología y Ciencias Marinas
> Universidad Simón Bolívar
> Caracas, Venezuela
C. Michael Barton
National Center for Atmospheric Research &
University Consortium for Atmospheric Research
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
