[GRASS-dev] Re: [GRASS GIS] #1632: v.proj: split_q.c:69: RTreeClassify: Assertion `!p->taken[i]' failed. in the same projection
GRASS GIS trac at osgeo.org
Sat Mar 31 09:06:09 EDT 2012
the same projection
  Reporter:  pertusus  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  7.0.0
 Component:  Vector    |     Version:  6.4.2
Resolution:  fixed     |    Keywords:
  Platform:  All       |         Cpu:  x86-64
Changes (by mmetz):
  * status:  new => closed
  * platform:  Linux => All
  * resolution:  => fixed
  * milestone:  6.4.3 => 7.0.0
Comment:
 This is a bug in the spatial index used by the vector library in 6.x.
 Import works fine in 7.0, which uses a different spatial index. The result
 seems to be ok, because the bounding boxes are identical and the vector
 features seem to be identical judged by visual inspection. This bug fix
 can not be backported and will thus not be fixed in 6.x.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1632#comment:1>
