[GRASS-dev] Re: [GRASS GIS] #1464: Bug on v.buffer
GRASS GIS trac at osgeo.org
Tue May 1 06:59:37 EDT 2012
 Reporter:  leonidas  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  svn-trunk
 Keywords:  v.buffer  |    Platform:  All
      Cpu:  All       |
Comment(by neteler):
 Replying to [comment:4 mmetz]:
 > Fixed in trunk in r51580, as long as GRASS is compiled with GEOS.
 Neither one of the two GRASS-internal buffering methods is working
 correctly. Moreover, the GEOS method is the only one allowing for internal
 buffers with negative distances. Should we disable v.buffer if GEOS is not
 available (rather have no result than a wrong result)?
 I suppose that GEOS is available for all relevant platforms nowadays (and
 it became
 official OSGeo project yesterday). So I support this suggestion.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1464#comment:5>
