[GRASS-dev] Re: [GRASS GIS] #1650: v.net.salesman - add sequence output
GRASS GIS trac at osgeo.org
Wed May 2 04:52:36 EDT 2012
 Reporter:  gfleming     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:2 mlennert]:
 > No idea if it is linked to your commit, but I get a segfault running the
 following on a fresh checkout (r51586)  & compile of trunk (including a
 'make distclean'):
 > v.net in=streets_wake points=schools_wake out=streets_with_schools
 operation=connect thresh=50
 > v.net.salesman in=streets_with_schools out=salesroute ccats=1-999
 > I've attached the backtrace.
 > If it's not linked, I can open a separate ticket.
 I can not reproduce it on Linux 64 bit, but I suspect buffer overflow in
 buf and buf2 according to the backtrace, see also my recently added
 comment in the source code [0]. I will change this verbose message to a
 debug message and make it print out one arc / node per line, that should
 avoid the buffer overflow. The graph in the example has 994 arcs, but buf
 can only hold a bit less than 300 arcs with 5-digit category numbers.
 Markus M
 [0]
 https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.net.salesman/main.c#L459
Ticket URL: <http://trac.osgeo.org/grass/ticket/1650#comment:3>
