[GRASS-dev] Re: [GRASS GIS] #1650: v.net.salesman - add sequence output
GRASS GIS trac at osgeo.org
Thu May 3 05:48:37 EDT 2012
 Reporter:  gfleming     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mlennert):
 Beautiful, especially the new sequence parameter !
 Just one small issue: when using sequence=- the result is printed to the
 terminal before the build process output. This can be solved by using the
 quiet flag, but is there any way to do this even without that flag ?
 Glancing over the code, I don't see any other way than creating some
 temporary buffer which can then be output later, so we would be at the
 starting point of the problem again, except if there is a possibility to
 buffer to a temp file and then print out the results at the end.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1650#comment:6>
