[GRASS-dev] Re: [GRASS GIS] #1652: g.extension: provide option to use local source code instead of SVN
GRASS GIS trac at osgeo.org
Fri May 4 18:19:51 EDT 2012
 Reporter:  mlennert           |       Owner:  grass-dev@…
     Type:  enhancement        |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Installation       |     Version:  unspecified
 Keywords:  g.extension addon  |    Platform:  Unspecified
      Cpu:  Unspecified        |
Comment(by hamish):
 ? both source URL and compiled destination are configurable through the
 svnurl= and prefix= options.
 The GRASS_ADDON_PATH environment variable is also respected if it is set.
 Is there something else which would be helpful to use beyond that?
 e.g. avoid having to set svnurl=http://localhost/something and instead do
 srcdir=/path/to/...?  In that case why not just set up an alias:
   alias   gmake65='make MODULE_TOPDIR=/usr/src/grass/svn/grass65/'
 and then run `gmake65` from your source dir?
 Hamish
 ps- I think it's a fine thing to use the addons repo as a module
 incubation & development area; my method is to simply not activate the
 Makefile until it's ready for wider consumption. see also the grass
 sandbox repo for personal (but open) experimentation.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1652#comment:1>
