[GRASS-dev] unknown reference to G__gisinit
Tue May 8 18:38:54 EDT 2012
Markus Neteler wrote:
> > extern "C"
> > #include <grass/gis.h>
> > and it worked, just in case other people finds the same problem.
> Glad you found it. I have added a note to
> http://grass.osgeo.org/wiki/GRASS_and_C++
> (please expand that Wiki page)
If it's considered desirable to be able to use GRASS from C++, the
headers' contents should be bracketed with:
	#ifdef __cplusplus
	extern "C" {
	#endif
	#ifdef __cplusplus
	#endif
Without the 'extern "C" ...' qualification, C++ assumes that functions
have C++ linkage, meaning that the parameter types are embedded in the
symbol name (C++ allows function overloading, where multiple functions
can have the same name provided that they have different parameter
types).
