[GRASS-dev] Re: [GRASS GIS] #1650: v.net.salesman - add sequence output
GRASS GIS trac at osgeo.org
Wed May 9 05:41:30 EDT 2012
 Reporter:  gfleming     |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  Default      |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mlennert):
 Replying to [comment:7 mmetz]:
 > Replying to [comment:6 mlennert]:
 > > Just one small issue: when using sequence=- the result is printed to
 the terminal before the build process output. This can be solved by using
 the quiet flag, but is there any way to do this even without that flag ?
 Glancing over the code, I don't see any other way than creating some
 temporary buffer which can then be output later, so we would be at the
 starting point of the problem again, except if there is a possibility to
 buffer to a temp file and then print out the results at the end.
 > Done in r51602. The sequence is first written to a temp file and then at
 the very end written to stdout.
 Perfect, thanks a lot !
 This ticket can be closed for me. I'll just leave it open for now as a
 possible reminder for backporting to grass6dev.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1650#comment:8>
