[GRASS-dev] [GRASS GIS] #1655: problem compiling r.terraflow with g++ 4.7.0
GRASS GIS trac at osgeo.org
Tue May 15 05:34:03 EDT 2012
 Reporter:  hamish                    |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  critical                  |   Milestone:  6.4.3
Component:  Compiling                 |     Version:  6.4.2
 Keywords:  r.terraflow, libiostream  |    Platform:  Linux
      Cpu:  x86-64                    |
 for 6.4.2 on Debian/sid we're getting the following fail to builds:
 Errors in:
 /home/hamish/dev/grass/git/grass/lib/iostream
 /home/hamish/dev/grass/git/grass/raster/r.terraflow
 lib/iostream is fixed by backporting r50130.
 r.terraflow still fails with a number of "'foo' was not declared in this
 scope, and no declarations were found by argument-dependent lookup at the
 point of instantiation [-fpermissive]":
 .../raster/r.terraflow$ make
 mkdir -p OBJ.x86_64-pc-linux-gnu/FLOAT
 c++ -c -I/home/hamish/dev/grass/git/grass/dist.x86_64-pc-linux-gnu/include
 -g -O2   -DUSER=\"hamish\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT main.cc -o OBJ.x86_64-pc-linux-
 gnu/FLOAT/main.o
 In file included from /home/hamish/dev/grass/git/grass/dist.x86_64-pc-
 linux-gnu/include/grass/iostream/empq_adaptive_impl.h:30:0,
 linux-gnu/include/grass/iostream/ami.h:41,
                  from common.h:27,
                  from main.cc:39:
 gnu/include/grass/iostream/empq_adaptive.h: In constructor
 'EMPQueueAdaptive<T, Key>::EMPQueueAdaptive(long int)':
 gnu/include/grass/iostream/empq_adaptive.h:53:47: warning: delegating
 constructors only available with -std=c++11 or -std=gnu++11 [enabled by
 default]
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT common.cc -o OBJ.x86_64-pc-linux-
 gnu/FLOAT/common.o
                  from common.h:27,
                  from common.cc:35:
 default]
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT stats.cc -o OBJ.x86_64-pc-linux-
 gnu/FLOAT/stats.o
                  from stats.h:29,
                  from stats.cc:30:
 default]
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT fill.cc -o OBJ.x86_64-pc-linux-
 gnu/FLOAT/fill.o
                  from fill.h:22,
                  from fill.cc:24:
 default]
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT types.cc -o OBJ.x86_64-pc-linux-
 gnu/FLOAT/types.o
 -DPACKAGE=\""grassmods"\" -DELEV_FLOAT ccforest.cc -o OBJ.x86_64-pc-linux-
 gnu/FLOAT/ccforest.o
                  from ccforest.h:27,
                  from ccforest.cc:19:
 delegatinghamish at sid-amd64-vm:~/dev/grass/git/grass/raster/r.terraflow$
 make
 gnu/FLOAT/main.o
                  from common.h:27,
                  from main.cc:39:
 default]
 gnu/FLOAT/common.o
                  from common.h:27,
                  from common.cc:35:
 default]
 gnu/FLOAT/stats.o
                  from stats.h:29,
                  from stats.cc:30:
 default]
 gnu/FLOAT/fill.o
                  from fill.h:22,
                  from fill.cc:24:
 default]
 gnu/FLOAT/types.o
                  from ccforest.h:27,
 default]
 linux-gnu/include/grass/iostream/empq.h:35:0,
 linux-gnu/include/grass/iostream/empq_impl.h:26,
 linux-gnu/include/grass/iostream/ami.h:39,
                  from ccforest.h:27,
 gnu/include/grass/iostream/minmaxheap.h: In instantiation of 'HeapIndex
 MinMaxHeap<T>::fill(T*, HeapIndex) [with T = keyvalue<int>; HeapIndex =
 unsigned int]':
 gnu/include/grass/iostream/empq_impl.h:674:67:   required from 'bool
 em_pqueue<T, Key>::min(T&) [with T = keyvalue<int>; Key = int]'
 gnu/include/grass/iostream/empq_adaptive_impl.h:237:2:   required from
 'bool EMPQueueAdaptive<T, Key>::min(T&) [with T = keyvalue<int>; Key =
 int]'
 ccforest.cc:164:4:   required from 'void ccforest<T>::findAllRoots(int)
 [with T = int]'
 ccforest.cc:340:16:   required from here
 gnu/include/grass/iostream/minmaxheap.h:747:5: error: 'insert' was not
 declared in this scope, and no declarations were found by argument-
 dependent lookup at the point of instantiation [-fpermissive]
 gnu/include/grass/iostream/minmaxheap.h:747:5: note: declarations in
 dependent base 'BasicMinMaxHeap<keyvalue<int> >' are not found by
 unqualified lookup
 gnu/include/grass/iostream/minmaxheap.h:747:5: note: use 'this->insert'
 instead
 gnu/include/grass/iostream/minmaxheap.h: In instantiation of 'void
 UnboundedMinMaxHeap<T>::grow() [with T = keyvalue<int>]':
 ccforest.cc:340:38:   required from here
 gnu/include/grass/iostream/minmaxheap.h:780:2: error: 'allocateHeap' was
 not declared in this scope, and no declarations were found by argument-
 gnu/include/grass/iostream/minmaxheap.h:780:2: note: declarations in
 unqualified lookup
 gnu/include/grass/iostream/minmaxheap.h:780:2: note: use
 'this->allocateHeap' instead
 gnu/include/grass/iostream/minmaxheap.h:786:2: error: 'freeHeap' was not
 gnu/include/grass/iostream/minmaxheap.h:786:2: note: declarations in
 unqualified lookup
 gnu/include/grass/iostream/minmaxheap.h:786:2: note: use 'this->freeHeap'
 instead
 make: *** [OBJ.x86_64-pc-linux-gnu/FLOAT/ccforest.o] Error 1
  * Debian's gcc 4.7.0-8
  * Debian's eglibc 2.13-32
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1655>
