[GRASS-dev] Adding NetCDF to GRASS7 configure
Martin Landa landa.martin at gmail.com
Wed May 16 06:07:27 EDT 2012
2012/5/16 Sören Gebbert <soerengebbert at googlemail.com>:
> integrate NetCDF in the configuration process? I have patched the
> files "configure.in"  and "Platform.make.in". Do i need to modify any
> additional files? How should i generate the configure script with
> autoconf, so that it is compatible with the current configure script?
running autoconf2.13 to update configure script should be enough.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
