[GRASS-dev] r.mapcalc in trunk with pthreads broken
Markus Metz markus.metz.giswork at googlemail.com
Wed May 16 12:01:02 EDT 2012
I am observing corrupted output from r.mapcalc in trunk if compiled
--with-pthread. The result is not identical to the one obtained
--without-pthread. The mapcalc expression included the functions
eval(), min(), and max(), in case that helps. Open a ticket?
Markus M
