[GRASS-dev] r.mapcalc in trunk with pthreads broken
Thu May 17 01:33:53 EDT 2012
Markus Metz wrote:
> I am observing corrupted output from r.mapcalc in trunk if compiled
> --with-pthread. The result is not identical to the one obtained
> --without-pthread. The mapcalc expression included the functions
> eval(), min(), and max(), in case that helps. Open a ticket?
Yes.
Also, can you describe whether (and how) the behaviour is affected by:
	export WORKERS=1
The WORKERS environment variable controls the maximum number of
threads used; the default value is 8.
