[GRASS-dev] [GRASS GIS] #1668: r.regression.line F-test incorrect
GRASS GIS trac at osgeo.org
Thu May 31 06:08:14 PDT 2012
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mlennert):
 Replying to [comment:4 mmetz]:
 > You can compare to the grass7 addon r.regression.multi whose results are
 identical to those of R.
 This is what I did and actually r.regression.line with the above change
 gives the same result as R, not r.regression.multi (regressing the landsat
 bands 10 and 20 from the NC data set):
 F (R): 6268922
 F (r.regression.line with change): 6268922.212939
 F (r.regression.multi): 6268947.256273
 I think I've found the problem in r.regression.multi:
 Instead of
 F = ((SStot - SSerr) * (count - n_predictors)) / (SSerr * n_predictors);
 it should be
 F = ((SStot - SSerr) * (count - n_predictors - 1)) / (SSerr *
 n_predictors);
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1668#comment:5>
