[GRASS-dev] [GRASS GIS] #1779: v.net.centrality: output map has features' cat values in layer 2, but table connected to layer 1
GRASS GIS trac at osgeo.org
Fri Nov 2 05:54:52 PDT 2012
  Reporter:  mlennert     |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Vector       |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  v.net.centrality layer
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by mlennert):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 mmetz]:
 > Replying to [ticket:1779 mlennert]:
 > > v.net.centrality creates an output map with points representing those
 nodes for which centralities were calculated. As customary in network
 modules (at lest in trunk), these points have their cat values in layer 2.
 The attribute table is linked to layer 1, however.
 > > As the output is only points, IMHO the cat values should be in layer
 1.
 > Right, fixed in all branches with r53637-9.
 Thanks for the quick fix ! Closing ticket.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1779#comment:2>
