[GRASS-dev] [GRASS GIS] #1789: v.hull: should not use
GRASS GIS trac at osgeo.org
Fri Nov 9 13:18:52 PST 2012
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-releasebranch64
 Keywords:  v.hull       |    Platform:  All
      Cpu:  All          |
Changes (by mmetz):
  * type:  defect => enhancement
  * milestone:  6.4.3 => 7.0.0
Comment:
 Replying to [ticket:1789 neteler]:
 > If the current region is not set to the vector map, v.hull
 > fails
 In this case, you need to use the -a flag to ignore the current region.
 I have changed the behaviour in trunk such that the current region is only
 respected if the (new) -r flag is set (see also other v.in.* modules). The
 -a flag has been removed.
 Additionally, I have added selection options 'cats' and 'where'.
 All changes are in r53759.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1789#comment:1>
