[GRASS-dev] Standalone GUI modules: Makefile
Sun Nov 11 15:19:44 PST 2012
Vaclav Petras wrote:
> > Basically: how important is it for each module to have a WXPGM
> > distinct from PGM?
> Hmm, it is not so important. The main reason is that we need two
> manual pages. One for module (g.gui.mapswipe.html) and one for
> component (wxGUI.MapSwipe.html).
> To simplify things, we can use name wxGUI.g.gui.mapswipe.html. But I
> don't like "wxGUI.g.gui" part. Naming convention should lead to nice
> names. wxGUI.mapswipe.html would be nice (mapswipe is also the
> directory name).
Prefixes and suffixes can be added and removed easily enough, so
having g.gui.mapswipe.html and wxGUI.mapswipe.html is straightforward.
So if you have a subdirectory for modules, you could do e.g.:
MODULES := $(patsubst g.gui.%.py,%,$(wildcard g.gui.*.py))
CMDHTML := $(patsubst %,$(HTMLDIR)/g.gui.%.html,$(MODULES))
GUIHTML := $(patsubst %,$(HTMLDIR)/wgGUI.%.html,$(MODULES))
PYFILES := $(patsubst %,$(SCRIPTDIR)/g.gui.%,$(MODULES))
default: $(CMDHTML) $(GUIHTML) $(PYFILES)
$(HTMLDIR)/g.gui.%.html: g.gui.%.html g.gui.%.tmp.html | $(HTMLDIR)
	$(PYTHON) $(GISBASE)/tools/mkhtml.py g.gui.$* $(GRASS_VERSION_DATE) > $@
$(HTMLDIR)/wxGUI.%.html: g.gui.%.html | $(HTMLDIR)
	$(INSTALL_DATA) $< $@
g.gui.%.tmp.html: $(SCRIPTDIR)/g.gui.%.py
	$(call htmldesc,$<,$@)
$(SCRIPTDIR)/g.gui.%.py: g.gui.%.py | $(SCRIPTDIR)
	$(INSTALL) $< $@
