[GRASS-dev] graph function in r.mapcalc
Mon Nov 19 10:07:10 PST 2012
Paulo van Breugel wrote:
> It works perfectly in my (limited) testing, great! I am impressed.
> I am not sure what you mean by "re-factor the common code", but I hope it
> will be possible to include this graph2() function as a standard as it
> makes, i.m.h.o. the function more user-friendly.
Can you add a "wish" to the bug tracker?
> p.s. I applied the patch to my GRASS7, can I also apply the patch to
> GRASS64?
I'm not sure that the patch will apply to 6.4, but there's no
fundamental reason the same change cannot be made.
